Choosing a Welding Coupon
Good afternoon, eng-tips! I will outline my question, code requirements, and thoughts.
My question is about tempering temperature on 4130 and will be below. I have gone through our inventory of material to try and choose the best coupon suited for an updated SAW welding procedure with a prolonged PWHT. I currently have one with only a 4 hour cook that was done long ago. We now have a need to match this process to others with an 8+ hour (1150-1200°F) PWHT. So far I have found a few pieces of material that I am considering. My criteria on looking through our inventory was the following:
Carbon Content - I am trying to get the lowest that we have for hardness/preheat purposes. Everything is between .309-.32
Vanadium Content - Same thing here. The lower the better. Range of inventory: 0.006-0.035. I have heard/read that this is will increase hardness
Tensile/Yield - Considering the prolonged PWHT on the coupon, I am trying to find something well above the minimum of 75ksi yield. I am making an assumption and going off of past data that it can drop >5ksi if the interpass temperature is too great along with the PWHT.
Hardness HB - So far my choices have come down to a few coupons in the range of 217-225.
Charpy: 15/20 ft/lb
CODES: API 6A / ASME IX / NACE MR0175 / DNV OS-E-101
The big question I have is how much affect will the tempering temperature of the base metal effect the HAZ (250 HV max.) after welding and PWHT. I know that the tempering temp (from the mill) effects the hardness of the material, but not sure if it has much bearing on the welding side of it. I would imagine it does. Our PWHT maximum temperature will be 1200°F (I usually cook at 1175°F). Out of the coupons that I am considering, the tempering ranges are 1202 - 1300°F. In the past it was told to me that a good rule of thumb is 50°F below the temper So i always chose a coupon with ~1200°F temper. Would it be that detrimental to use a 1300°F temper being that I can only hold a 1200°F max PWHT?
See attached for what I am looking at. Thank you everyone who read through this!
Charpy: 15/20 ft/lb
RE: Choosing a Welding Coupon
Thanks for catching that. I was in a hurry putting it together yesterday. I agree that the PWHT should never be over tempering temp. Most of the material we get will be tempered around 1200. I was just curious if it would be detrimental to use a 1300 tempered coupon during PQR testing. It has a bit lower hardness and strong mechanicals. That's the only reason I am considering it even slightly.
I do get your statement about if in production we have a part tempered at 1200 and our WPS states 1175-1200. I'm sure cooking that closely to temper wouldn't be so great.
