Bleed Ring
Bleed Ring
Hello Folks,
We bought a few drip rings, 3", 600#, with 1/2" tap. They all came in 1.5" thickness. They all also have a socket shape inside them, please see attached sketch.
Our Client is insisting to weld a Sockolet on the tap (3" x 1/2") and proceed with welding the nipple and valve.
The SOL can't fit into the drip rings between the two flanges.
Please kindly take a look at the attached sketch.
IMHO, the SOL is redundant and we should just insert an 1/2" pipe and weld around and proceed.
Any comments/advise/idea is highly appreciated.
http://files.engineering.com/getfile.aspx?folder=5...
Frank
Frank
RE: Bleed Ring
RE: Bleed Ring
What is the diameter of the socket in the Bleed Ring?
Sometimes its possible to do all the right things and still get bad results
RE: Bleed Ring
the socket is 20 mm diameter with 10 mm depth and then it reduces to 13 mm, in order for a 0.5" pipe to be inserted.
The drip ring has come as 1.5" width and 5.75" diameter. It can't be welded to a SOL as space is not enough.
Thanks.
RE: Bleed Ring
I suggest you try the following:
1. Forget the SOL
2. Get a 1/2"NPS Schedule 80 Nipple (6" long) and see if it will fit in the socket
3. May require a little shaving.
3. If it fits then perform a standard fillet weld for a 1/2 inch Socket Weld
RE: Bleed Ring
1. Scrap the SOL
2. Get a 1/2" SCH 80 PE x PE nipple (2" long)
3. Socket weld the nipple to the bleed ring port
4. Socket weld a 1/2" SW x SW ball valve to the nipple
(Don't forget your gap rings for socket welds)
RE: Bleed Ring
