Export all settings of NX from one computer to another
Hi to all!
I need to export all settings of NX from one computer to another. I know there is a lot written about this topic, but it always about mtx and dpv.
We have a lot of personalized things:
Reuse library
Material library
Drawing standards
Drawing templates and pax
And very important: environment variables
Any idea of how to do this export in easy way?
Can I copy and paste my entire Siemens folder?
Do I have to write again all environment variables?
RE: Export all settings of NX from one computer to another
First you need to find in which Paths you have stored all these files...
Then it should be easy to transfer them...
Check the NX logfile...there you should be able to find the (customized) locations...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
This is one of the reasons I like the NXcustom setup that Rob Cohon created, as it keeps the local install of NX untouched, and the fine tuning is done within the NXcustom folder, and much more portable.
-Dave
NX 9, Teamcenter 10
Thank you Nutace.
Gunman, that sounds really interesting and I would like to learn about this topic. I've been looking up on the internet. Do you know where I can find the best info about it? A Pdf or something like that?
Teacher and at the same time apprentice of NX / UG. I will try to help as much as I can. However be patient with my poor English.
ups! I was writing an answer so I didn´t see the last one. Thank you cowski!
This is sooooo perfect!! Thank you to all!bigsmile
