dll for CSI Bridge
dll for CSI Bridge
dll for CSI Bridge
Hi. I am triying to automate things with CSI bridge and the OAPI, and vba in excel
However i can not reference the required dll for the OAPI to work. I triying to load the CSiBridge18.dll, but excel does not let me do it.
I think that is the correct dll, but i am not totally sure. Does anybody know what i could do? Has somebody experience with csi bridge and OAPI, and could tell me if CSiBridge18.dll is the correct dll?
thanks in advance
RE: dll for CSI Bridge
I found the solution. I had problems because there was some incompatibility between the CSI software, and Excel. I solved it. in a virtual machine, i have windows xp. There, i installed the 32 bit version of CSIBridge, and that way, I have available the csiBridgeApi.dll. That dll implements all the functionality for working with OAPI and excel.In my opinion, it is a very powerful utility.
Hello Borja1980,
Would you share an example of vba code to use CSiBridge? I am really new at this, but I would
like to learn.
Thank you very much.
