limited replacement of surfaces in NX10
I have a surface model based on offsets of a base surface. As the design has evolved i need some of the offsets to be run off of an additional base surface.
Is there a way to replace the original base surface with the new one but only effecting a select few of driven surfaces leaving some of the offsets still driven by the original surface.
i have delved into the replace command, but this seems to expect you to be replacing for everything.
thanks for the help
Rob
thanks for the help
Rob
RE: limited replacement of surfaces in NX10
John R. Baker, P.E.
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
