stress ratio fatigue stress amplitude allowable
Hi all,
I know this may sound like a very fundamental question, i just cant find an explanation in the literature.
R is defined as the ratio between the min and max stress, and depending its value has an impact on the fatigue test results by decreasing the stress amplitude as stress ratio decreases for the same number of life cycles.
This R ratio is in direct relation with the mean stress and another graph states that as the mean stress becomes larger the stress amplitude will decrease. This makes total sense as the mean stress will have a greater contribution and actual life of the part will be affected, but i think that mathematically it contradicts the previous R ratio relationship, because as R ratio increases, mean stress also increase.
I know this might be very simple.
I appreciate all the help you can provide.
RE: stress ratio fatigue stress amplitude allowable
Thanks for all your help
What do you mean by "fatigue allowable" ? The stress for the same life ?
the stress ? which stress ?? (max, alt, cycle, ...)
Looking at AR MMPDS they use Seq = Smax*(1-R)^n, so R = 0 Seq = Smax and R = -1 Seq = Smax*1.4 (approx). Then R = -1 will have a shorter life than R = 0 for the same Smax.
Restrict the discussion to cases where R < 1.00.
In the first graph, for a given alternating stress, as R increases (and thus the mean stress increases), the fatigue life decreases.
In the second graph, for a given alternating stress, as the mean stress increases (and thus R increases), the fatigue life decreases.
Consistent and logical.
My colleagues are weary of hearing me advise them not to treat R as though it is a physical parameter. It is not. It is a by-product of the measurements (or calculations). For monotonic loading, consider a structural detail in terms of the stress cycle and the fatigue life. The stress cycle can be defined by two physical parameters:
● maximum stress, and
● minimum stress.
An increase in maximum stress while minimum stress is kept constant results in a decrease in fatigue life.
A decrease in minimum stress while maximum stress is kept constant results in a decrease in fatigue life.
All else follows in terms of mean stress effects and R effects.
equally, alternating stress and R define a stress cycle.
R has just as much meaning as the three stresses referred to.
the second guide ... "A decrease in minimum stress while maximum stress is kept constant results in a decrease in fatigue life." is valid of +ve R.
-ve R cycles are often truncated to R = 0, conservatively.
Yes. A stress cycle can be defined using any two of:
● maximum stress,
● minimum stress,
● mean stress,
● alternating stress, and
● R
Other parameters could also be imagined. What I meant was that if the focus is on max and min stress, the intuition is easier.
Mathematically, sure. Physically, less so. R has no units.
Correct. It is also valid for for R<0.
I would hesitate to say that truncation of R<0 stress cycles is conservative. The best I think could be said is that sometimes it does not make the results less conservative.
For instance, when using high load transfer joint data, if the compressive part of an R<0 stress cycle is truncated, the damaging effect of the reversed fastener loading is lost, and the fatigue damage will be under-predicted.
Same kind of thing with open hole data. Truncation means that you loose the effect of the tensile stress at the hole periphery that occurs when the stress is compressive. The location of this tensile stress is not the same as the location of maximum stress when the gross stress is tensile, but still… Depending on the situation being assessed, this can be important.
The lucky thing is that in highly compressive stress fields, da/dn is of course relatively low, so even if the cycles to initiation are under-predicted, the subsequent crack growth is often slow.
With all your comments i could see now what was the problem. The allowables that i have are actually for Smax at different R ratios(unfortunately the test lab did not specified this at first) , so the Sa will be less for higher r ratios, now when using the goodman diagram it makes sense.
Thanks for sharing all of these key concepts,
