Automate a task in ACAD2002
How would I would go about setting something up that will fill in a title block names attributes for all drawings currently open in ACAD? I regularly have to electronically "sign" these drawings, sometimes sets of 30 or more. It would be of great help if I only had to type in the names/dates once, rather than 30+ times, or even copy w/ base point and pasting to original coordinates 30+ times.
Any direction would be appreciated. I'm just looking for a place to start.
I am new to autocad but fairly familiar with programming in Visual Basic and a few other languages.
RE: Automate a task in ACAD2002
Stephen E. Motichek
Project Consulting Services, Inc.
Its just tedious.
Its Freeware at http://www.angelfire.com/clone/ezscript
You cound make the title block all attributes and automatically fill in the info with a script -or- just have it repeat the text comands for each title block.
EZscript-Pro will repeat these command across all the drawings you want.
Good luck
This utility is allows you to create script files to process
if you are using Autocad 14, 2000+ & Lt versions. I use the product all the time for large volume drawing production. There are a number of templates and wizard scripts to help you, as well as the facility to create your own. You simply create the script then apply it to as many drawings as you want, the script runs with each drawing being opened,processed then saved/closed.
A must for all productive cad users who want to avoid repetitive tasks.
Graham Dury
Desco Ltd - England
