Deleting A Current Feature Causes Everything Above To Fail
Like the title says, I've got a model and if I delete, suppress or even edit with rollback, the entire model fails. Operations above that have nothing to do with the current feature just fail. Anyone have this happen?
RE: Deleting A Current Feature Causes Everything Above To Fail
NX8.5 - NX9 User
Is it towards the top of the model tree?
Part clean up will sometimes fix things. There are some warnings if you turn on all the options. To be safe you can make a copy of the file and turn all the options on.
If that does not work I would set current feature near the top of the part history. Then turn on features until I found the one that is the problem.
