Welded pipe joint efficiency for UG-27 calculation
I have SA-53E/B (welded pipe) used as a shell.
ASME section II partD gives 14600 psi for max allowable stress at 200F.
In notes it is indicated that this value (14600 psi) includes 0.85 joint efficiency factor.
I read the UW-12 and my understanding is that I can use E=1 in UG27 formula for required shell thickness, provided that 14600 psi (value that includes E=0.85) is used as maximum allowable stress.
Is my understanding correct.
No additional NDE has been performed other than those specified by SA-53.
Many Thanks,
Jakov11000
Many Thanks,
Jakov11000
RE: Welded pipe joint efficiency for UG-27 calculation
