Hi every one, I am modelling bea
Hi every one,
I am modelling beam to column bolted connection under impact load. Could you suggest the best normal contact type can I use between the bolt head to end plate and between nut to column. Also, just to let you know that I did not model the washers keeping direct contact between bolt head to plate and nut to column.
Ali
Ali
