insert ==>> curve ==>> A text
Hi
I want to use insert ==>> curve ==>> A text for
building a dial 0 to 360 in 10 deg steps with insert ==>> curve ==>> A text
I tried associative copy ==>> instance geometry but I can not change the A text
to 0,10,20,...,350 (after the instance geometry)
Is there a way to do this
Thanks in advanced
Thanks in advanced
RE: insert ==>> curve ==>> A text
You might be able to define expressions of 'height', 'width', in relationship to 'radius' so they all change by editing expression values.
Gary Bangs
www.flowserve.com
I mean change the text itself to 10,20,30,....
And not the expressions
Thanks in advanced
Gary Bangs
www.flowserve.com
In the posted part I want to change one of the "A" text pattern
say to the text "B" How I do that
Thanks in advanced
Then, you can double-click each one and change as desired. Depending upon how/if you want them linked, you could change the Expressions options that best suits your situation.
g.
Gary Bangs
www.flowserve.com
Thank you vary much for your help
Before your help I attended to build it with copy paste
36 times
The feature pattern do not build an object on the model navigator
That mean not parametric but maybe that all NX can suggest
Thank you again
NX hold them internally.
And I can't reach them
I feel NX need small effort to make it parametric
gbangs
TC 8.3.3
NX 8.5.3.3 MP11
