Shortcut or tips to creating isometric views time and time again
I often find myself creating isometric views other than the standard one, usually to show part details in different orientations. To do this I have to constantly go back to Tools > Options, click View and change the Arrow keys setting by typing either 45° or 35.264°.
This is starting to get old for me. Does anyone know of a more efficient way to do this?
Thank you!
Thank you!
RE: Shortcut or tips to creating isometric views time and time again
Go here Link
John H. Dunten, CD
Certified Drafter
You can rotate the view. Link
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
What I was trying to achieve was a way to quickly set up true isometric projections (45° along vertical axis and 35.264° along horizontal axis).
I found the solution right under my nose. In the part or assembly, after hitting the space bar turn on the "View Selector" (cube icon on upper right hand side of pop-up menu, available on SW 2013 and later). The tool will give you the option to select among the eight possible isometric angles by clicking on the corners.
http://help.solidworks.com/2013/English/WhatsNew/c...
David
Connect with me on LinkedIn. http://lnkd.in/fY7-QK
http://www.eng-tips.com/viewthread.cfm?qid=39233
-handleman, CSWP (The new, easy test)
Steve R SWCA (Solidworks Certified Associate)
http://www.3dlogix.com
https://www.youtube.com/user/3dlogix
http://www.sprdesign.com
