Boundary Element Method (mechanics) - Fortran
Hello, I'm new in fortran and I would need a help
I'm working on a boundary element method code from the book "Boundary Element Programming in Mechanics" by Xiao-Wei Gao and Trevor G.Davies.
This code is capable of analyzing linear single-region problems of arbitrary geometry in both two or three dimensions and calulate displacement, traction, and stresses the body suppose to manage. I've attached the code
I've also attached an input data file "CYLE2D".DAT" for a thick cylinder with internal diameter of 200 units and exernal diameter of 400 units, subjected to an internal pressure of 10 units under plane stress conditions. I would like to change the load conditions and apply an esternal load instead of the internal pressure and I would like to try a first case with a constand external load and a second case with a linear variable load.
Where can I change this condition in the input data file?
Thank you in advance!
RE: Boundary Element Method (mechanics) - Fortran
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
