NX9 - Drag and drop part loading not working
Why doesn't the drag and drop function work for opening a part or assembly in NX9?
I have the "Enable Drag and Drop Reorder" checked in Customer Defaults -> Part Navigator. Is there any other Drag and Drop function I should have checked?
RE: NX9 - Drag and drop part loading not working
IN what environment are you trying this? Standalone or Managed?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Same problem here. It was working a week or 2 ago. The symbol for the cursor changes to the red circle with a line through it indicating that it will NOT work. What gives? The Windows 7 environment? No changes to my NX profile. STANDALONE ENVIRONMENT. This feature does not work in TeamCenter.
Did you change Maintenance pack ?
NX9 / TC10.1.2
HP Zbook15
standalone environment ... all I do is update what I get, no personal changes in MP though
Do you want to open the part or add as a component?
Are there NO parts open in the session?
Does it work if you double click the .prt file instead of drag and drop?
Mark Rief
NX CAM Customer Success
Siemens PLM Software
1. Open the file
2. No part open
3. double click works
Quote (KVartusa)
1. Open the file
2. No part open
That looks good to me. I would contact GTAC.
Mark Rief
