No topology optimization results with applied moments.
Hello everybody
I am working on Siemens NX 8.5 and my focus is topology optimization of a component.
I was trying to add some moments acting on the model I am optimizing but I got some problems.
Actually with only force applied the simulation gives results which I can even analyse, while if I try to add a moment (I have to apply two of them) the simulation stops after the number of cycles it needs, but I am not able to open the results. It says that actually no results were obtained.
Is there anything in particular to do in order to run optimization simulations with moments?
Thank you
