How can i connect two point in abaqus?
how we can connect two point in abaqus?
i want to conncect two point with same u3, just u3?
help me plz
RE: How can i connect two point in abaqus?
you can use Connector in module interaction to connect two points in abaqus. first, you should create wire feature, second you should create section with link behavior and then assign section which previously defined to the wire feature
good luck
*Equation
