Shear Strength
Shear Strength
Hi
Could someone please let me know what is the range of shear strengh of annealed glazing specimens??
Thank you very much.
Don
Don
RE: Shear Strength
Shear strength snd ceramics don't usually go together: The typical-by-definition ceramic is very strong but extremely brittle. Glazing covers the ceramic, and so doesn't add anything really to the (lack of) shear strength of the assembly overall.
RE: Shear Strength
I am trying to cover window panels. Because I noticed that window panels are damaged due to the impact of windborne debris by making a hole at the point of contact. So I think the reason behind is punching shear failure. If I can find shear strengh of glazing panels then I can find allowable limit of force that can be sustained without occuring punching shear failure.
