Sketch dimension decimal places?
Is there a separate setting for displaying sketch dimension decimal places?
I would like to have my sketch dimension show as 4 place decimals, while drafting dimensions display as 3.
Thank you.
Ken
RE: Sketch dimension decimal places?
The one setting controls both drafting and sketch dimensions.
This is a good time to use the master model method and set up separate "modeling" and "drafting" template files. This way you can have different options in each.
www.nxjournaling.com
Thank you, cowski.
Also thank you for the suggestion.
