ASME 16.25 VS ASME 16.9 Beveled End
is pipe beveled end as per ASME 16.25 FigA2 accepted instead of ASME 16.9.
i have looked at the 2 and they both have the same beveling angle. but i just wanted to confirm.
aside from the contracual issues is it accptable technically to use pipes beveled as per ASME 16.25 with fittings as per ASME 16.9
thanks in advance
thanks in advance
RE: ASME 16.25 VS ASME 16.9 Beveled End
