High Hot Strength Material Data
I am searching for information regarding cast steel, stainless steel, & superalloy materials suitable for high temperature (>1000F) applications with higher hot strength. I have found several grades which are of interest A217, A297, A447, A487, & A351. I am looking for a resource(s) which have data (graphs etc.) of strength at elevated temperatures. Any help or suggestions of resources would be much appreciated.
Matt Smith
Mechanical Engineer
RE: High Hot Strength Material Data
Matt Smith
Mechanical Engineer
Your temperature is not high (by superalloy standards) so it falls in between. There are many high strength Fe and Ni based alloys used at 1000-1500F.
The degree of corrosion resistance needed is critical, as is the the actual nature of the service (steady or cyclic) and duration.
