Pump type selection
Pump type selection
For pumping 12% sodium hypo chlorite solution contractor is proposing to use Horizontal centrifugal pump ( cap 100 m3/hr and 3barg pressure).The MOC is Polypropylene.The pump is vendor standard.
For the above service any precautions to be taken in the design of the pump? Thanks to advise
RE: Pump type selection
Hypochlorite will offgas, which is the formation of gas in the piping system caused by heat, sunlight, low pumping rates, idle time, or a combination of these. System and pumps are often designed with venting at the discharge and highest point in the system to prevent vapor lock. Maintain a flooded suction condition if possible. Suction lines should be 2-3 times larger than the pump inlet.
