Help with choosing Analysis System
Hello! I am new to ANSYS and i am currently attempting to learn ANSYS Workbench. I am attempting to build a mesh of a Gas Electron Multiplier (GEM), and having trouble deciding which analysis system to use. I have been using Fluid Flow (Fluent) but not longer sure that is the correct choice. The GEM works as a gaseous ionization detector that collects electrons that are released by ionizing radiation. Which are then guided to a region with a large electric field, where a electron avalanche is initiated. Its geometry has a type of honeycomb structure, with a biconical structure. Pictures are attached.
All help is welcomed,
Mavila
