NXOpen Find Feature in by Name
Dear Forum,
Is there an easy way to find a feature by name.
I found this in the solution center for finding a line:
Public Function getLineByFeatureName(ByVal theName As String) As Line
Dim aTag As Tag = Tag.Null
Do
theUFSession.Obj.CycleByNameAndType(workPart.Tag, theName,
UFConstants.UF_feature_type, False, aTag)
If aTag.Equals(Tag.Null) Then Exit Do
Dim lineFeature As Features.Feature =
CType(Utilities.NXObjectManager.Get(aTag), Features.Feature)
Return lineFeature.GetEntities()(0)
Loop While True
Return Nothing
End Function
RE: NXOpen Find Feature in by Name
An easier way (IMO) would be to iterate through the features collection querying the name property of each. When you find the feature with the desired name, save it and stop looking.
CODE
for each temp as features.feature in workpart.Features
  if temp.name = "magic value" then
    myFeature = temp
    exit for
  end if
next
www.nxjournaling.com
