Cutting a long piece on a 3015 nt.
Has anyone made a cut longer than 120" on a 120" table? Like 128". Can you do it in one cut or do you have to spin the piece. On a fom2 3015 nt.
RE: Cutting a long piece on a 3015 nt.
I haven't looked at the programming manual in a while. Popular convention is to scan once in the x, for 1" to the edge, x=0 then two along the y. I think its possible to scan the edge closest to the laser cabinet and then two scans on the y.
I think its possible to cut in the x area greater than 120.8661" but it would burn the tubing on then end of the shuttle table, It would probably burn the little deck area after the shuttle table and before the laser cabinet, and there wouldn't be any dust / smoke collection in that zone either.
Next time I am on a machine like that, I'll look at the parameters and see how tricky it would be.
I only changed one parameter, 6933 this is for position switch #4. I took 14" x 25.4 x 1000 and added that to the original value.
