2 Speed Motor Overloads
Replacing a set of 2 speed motor starters. The motors are two speed one winding (2S1W) motors. In the high speed the low speed motor T leads are shorted.
Question is the placement of the overloads specifically on the low speed leads. Should the low speed overloads see the current of the low speed leads while in high speed?
This is strictly in question as to where to pick off for the shorting of the low speed leads.
RE: 2 Speed Motor Overloads
