Wind load for Small room inside a huge structure
I have a a small room inside a huge structure (factory) but not connected to any part of the big structure I don't know if I should take in my consideration the effect of wind load or not because the big structure is already designed with wind load
RE: Wind load for Small room inside a huge structure
If not, the large building will shield the small building if it is inside the big building.
As JAE indicated, there's the code provision for 5 psf horizontal load on interior partitions.
When you look at the equations for MWFRS and C&C Wind loads, there's a component for interior pressure effects, GCPi.
This load is greater than 5psf (5.7psf for my recent calcs with GCPi = +/- 0.18) but ASCE 7-16 is going to add a category for partially enclosed buildings with GCPi = +/- 0.55 (17.5 psf).
How is it that we design our C&C for an internal pressure of 5.7 (soon to be 17.5), but our interior walls for an internal pressure of 5psf?
BA
The minimum interior pressure as I have always known it was 5 psf. It is stated that way in the code. But that is exactly what it is named, a minimum. It is up to the engineer to decide what an appropriate loading is for their conditions, but it must be at least 5 psf.
I haven't dealt with "tunneling" before. Perhaps i under-designed them?
The partition between stalls of a carwash is a good example of that.
BA
1607 LIVE LOADS
1607.13 Interior walls and partitions. Interior walls and partitions that exceed 6 feet (1829 mm) in height, including their finish materials, shall have adequate strength to resist the loads to which they are subjected but not less than a horizontal load of 5 psf (0.240 kN/m2).
I see:
5 psf in 1607.13 under LIVE LOADS in IBC 2009
5 psf in 1607.14 under LIVE LOADS in IBC 2012 & 2015
5 psf in 13.5.8.1.3 for seismic in ASCE 7-05.
I don't see this provision in ASCE 7-05 for wind. Can anyone pin-point it for me?
Thank you!
I would consider designing the walls for a partially enclosed condition if the building meets the criteria to being classified as such.
BA
