zuken E3 export options into NX routing
I want to know how to export file from Zuken E3 into NX routing. We exported .plmxml file once (did not know what settings to make) resulted in no wiring information inside NX.
I want to understand what setting needs to be done in Zuken E3, so that all wiring information is imported into NX. I would like the export to be as .plmxml file.
Attached images "zuken export.jpg" shows no wiring information & image "all information.jpg" shows when imported properly with correct setting.
http://files.engineering.com/getfile.aspx?folder=7...
please need some advice to solve this issue.
