Disappearing Detail View...
So I have a detail view that won't stay displayed. Usually when this happens, I change the view state from 'Hidden Lines Visible' to 'Shaded With Edges' - or vice versa. I do this once and it never gives me trouble in that session again.
This time though my little trick doesn't work. It's like the view is hidden 'behind' something - but it's not.
Any thoughts?
Thanks in advance.
SW Professional 2015 SP 5.0
SW Electrical 2D/3D SP 5.0
64 bit
Intel Xeon X(R) CPU 3600 @ 2.80 GHz
8.0 GB of RAM
NVIDIA Quadro 2000
RE: Disappearing Detail View...
This is crazy. I have the exact same view on two other Sheets - no problems at all.
(I guess I can re-do the entire drawing.)
64 bit
8.0 GB of RAM
NVIDIA Quadro 2000
Have you tried Rt. Click, View, Reset Sketch Visibility? This usually works for me. You have to click in the view area though.
Didn't try that. Thanks, but that didn't work - however it prints out just fine. ??!?!
This has to be 'operator error' - I'm sure of it, I just don't want to re-do the drawing.
64 bit
8.0 GB of RAM
NVIDIA Quadro 2000
Nella95,
I can't say for certain but this problem seems familiar for some reason. I recall my fix was delete view then do an undo delete.
Hope this helps.
Samuel
