Radius to the outermost tube hole center
Dear all,
In heat exchanger tubesheet how to calculate radius to the outermost tube hole center and also distance between inner most tubecenters.
Please do needful,
Thanks & Regards,
Satya
Please do needful,
Thanks & Regards,
Satya
RE: Radius to the outermost tube hole center
Distance between innermost tube centers is the normal distance between centers of tube rows across a pass lane, u-bends or what have you. Normally only applies to multi-pass units.
Really, these are very basic concepts. My advice is that you study your Code book, or whatever reference materials you have available, including the Help facility on any software you may be using.
Mike
Thank you..definetly i'll go for code.
Satya.
