Inventor UCS & default sketch plane orientations
Hello folks... new to Inventor, been using AutoCAD near daily at work for about 12 years or so. I'd like to change my default UCS orientation AND the default sketch planes' orientations to be +X=right/east, +Y=north/into screen and +Z=up. I've figured out how to change the orientation of the View Cube so that my Front View is +X to right and +Z to up, and the Home View to be an iso view from the southwest with everything oriented how I would like. However, when I initiate the Sketch command, my XY sketch plane is still vertical, not like the default views of the UCS planes.
I've looked online and there's so many people that want to argue about which way is right or wrong; that's not my point here. Mathematically, any three orthogonal axes are legitimate, but as a practical matter, users interface with other things they are used to working with e.g. CAD, spreadsheets, etc. I don't believe there's a "right" orientation, I'd just like to change mine to the way I'm used to. Any help would be greatly appreciated.
RE: Inventor UCS & default sketch plane orientations
tools..application options.. part tab.. "Sketch on new part creation" section.. Change that to whatever works for you..
There is also the view cube Options dialog accessible by right clicking on the view cube and selecting options.. (default viewcube orientation)
Between those 2 you should be able to set it exactly as you want..
I'd highly suggest you go through the Autodesk discussion forums..
You will get answers in minutes.. vs potentially waiting days here..
http://forums.autodesk.com/t5/Inventor-General/bd-...
