waterproofing concrete on metal decking
I have an exterior mezzanine that will have an occupied space below. This mezzanine needs to be completely watertight. The problem is that metal deck below the concrete and waterproofing above the concrete traps all the moisture of the slab inside. Has anyone ever had to waterproof an elevated concrete slab on metal decking?
RE: waterproofing concrete on metal decking
A second option is to provide a fluid applied, reinforced membrane on the concrete deck in multiple layers with the final layer having coarse sand broadcast onto the membrane before it dries. If you use this option, make sure the manufacturer approves its membrane for roofing application and that your local code jurisdiction will also approve it as a roofing membrane. Option 1 will not require this step as it is already an approved roofing system.
Ron - there isn't an architect involved on this one and the code issue that you brought up is a good one. I recommended a roofing membrane to the client (contractor) and they told me that the owner is ok with some leaking (going to be a bathroom below). I'm going to call out a waterproofing system on my drawings to cover my rear and they can do what they want.
Teguci - I'm strongly urging for them to properly waterproof the slab. I don't think they realize how much water can get through a small crack.
This is a patio at a restaurant and they will have bathrooms below it. May not be end of world if water gets through, but would be stupid if they didn't try to protect their investment.
If the code expects a roof, then design a roof (See Chapter 15, IBC). No more, no less. If they want to "value engineer" (btw...I hate that term!)your design away and you're not involved in construction/contract administration, then so be it...you won't know. If you are involved in C/CA, then you will have an obligation to write a letter recommending against their actions, but you still won't likely be able to do anything about it....the difference is that you will have met your standard of care in two respects...the design and the obligation to warn against code violations.
One thing to keep in mind....if they get a permit to construct based on your proper design and they fundamentally change it, there might be a violation of the code from that action alone, without regard to what they change it to. The administrative portion of the code (Chapter 1) requires resubmittal to the AHJ (Authority Having Jurisdiction) of design changes.
Good luck.
This seems like once you have seen it, the it cannot be unseen and must be addressed by all involved. If ignored you are potentially opening yourself up to a world of pain later on.
"It is the understanding of the structural engineer that the elevated floor shown on this plan will cover an occupied space. Waterproofing is outside of the scope of the structural engineer, but it is strongly recommended to provide either a waterproofing membrane system rated for pedestrian use or a waterproofing coating such as sikalastic mt primer with sikalastic 710/715/735/ AL traffic system. If waterproofing is installed, metal decking should be vented. Manufacturer will pre-punch holes. It is highly recommended that a building envelope consultant be retained to fully detail the waterproofing system.
Furthermore, I intend to add a note similar to this: "Structural drawings provided by ......INC cover only items related to structural portion of project. ......LNC takes no responsibility for architectural, mechanical, civil, building envelope, or any other disciplines as these are outside of the services provided by ......LNC. ......LNC recommends that these disciplines be consulted to ensure the constructed deck meet all code requirements as this deck is considered a roof assembly."
I don't have any legal experience and am sure that you could shoot holes through this. If you have any advice regarding this, I'm all ears.
I would edit to the following:
"It is the understanding of the structural engineer that the elevated floor shown on this plan will cover an occupied space. Waterproofing is outside of the scope of the structural engineer. It is highly recommended that a building envelope consultant be retained to fully detail the waterproofing system."
Leave it at that!
1) If the top is completely waterproof then you're inside the building envelope like any normal composite deck and there should be no water. No vents required.
2) If the top is not waterproof then water will seep down through the concrete and get trapped at the deck causing rampant corrosion. Vents required.
Building envelope is not my strong suit however.
Kootk - I could see that if they didn't water proof and I called out for vented deck and they got cracking in the slab and water poured through the deck that I would get fingers pointed at me. If the deck is not vented, the deck will rust out over time, but I would make sure the reinforced concrete cans pan without the deck.
So you want the deck to serve as poor man's waterproofing and rust out? Keep in mind that, if water is getting to the deck and corroding it, the rebar may not be far behind. You know, unless you're planning on galvanized/stainless rebar.
(I agree with Ron, just reference to others for waterproofing. If there are no others, the client should seek advice from others. You can guide them in the right direction but if you aren't comfortable with specifying something then don't be forced into it)
Agent666 - yes, I agree - architect should be involved.
The reason for venting the deck is so that moisture from the concrete can escape thru the venting. The general principle is that concrete should be allowed to breathe and should not be totally encapsulated (as would be the case if you put a non-perforated metal deck on the soffit and a waterproofing membrane on top).
Where a metal deck is used on the soffit, it is required to be able to breathe when a waterproofing membrane is placed on the top surface -- see CSA Standard S413 (although this Standard is for parking garages, the general principle applies to other structures).
The issue of venting has nothing to do with whether the waterproofing membrane leaks or not. If it leaks, you are in trouble irrespective of whether the deck is vented or not. Acoustic deck has punched holes that may be sufficient for the venting, but the juice from the concrete may come thru the acoustic perforations, although that mat be acceptable. There are membrane people (such as Neoguard) who claim that their membrane is "breathable" but there are no standards for breathability, so I am not comfortable about it. A few years ago membrane manufacturers would not warrant the membrane if placed on slab on un-vented metal deck. Not sure what their current position is.
I have to run now but on the weekend I can send you the excerpt from CSA S413 that deals with this if you like.
If there are corrosive deicing chemical applied in winter, then the steel deck is even a worse idea.
The whole thing would be much better if it were a formed soffit and not a metal deck. Yes it is more expensive to form it, but you tend to get what you pay for.
Sounds like you have an unwise client if he/she says that leakage is acceptable. Don't become a prostitute by going along with something you know is wrong. The person telling you leakage is ok, will have disappeared when the leakage occurs and you will be left with the problem.
The attached position paper from SDI actually seems to be in line with sponcyv's thinking.
I am curious to see the CSA standard for parking garages. I wonder if the vented deck is required because the concrete can be flooded without any waterproofing. I did a little searching and here are a couple articles mentioning vented deck for use in parking garages. The second also recommends vented decks when the concrete is exposed to weather (I don't consider concrete covered by a roofing membrane to be exposed to weather)
http://msc.aisc.org/globalassets/modern-steel/arch...
http://eng.lacity.org/techdocs/technical_papers/Me...
If a true roofing waterproofing system with vented deck is not in the cards, I would consider the following:
1. Use heavy mesh instead of bars for better crack control
2. Require G120 galvanizing on the metal deck - never use G90 for exterior
3. Protect the top surface of the concrete with a 100% solids silane sealar. It is vapor permeable and will not cause problems over metal deck, unlike like a urethane traffic membrane. Lasts at least 5 years before needing re-applied. Cost about $0.80 per square footing in my neck of the woods.
4. f'c = 5 ksi min and w/c 0.38 with integral corrosion inhibitor along with proper air
Hope that gives some ideas
"It is imperative Cunth doesn't get his hands on those codes."
1. The minimum deck slope shall be 1/4:12.
2. If an overburden or wearing surface is not to be installed, the waterproofing system must be approved by the manufacturer for use in vehicular and/or pedestrian traffic locations.
3. The waterproofing assembly must possess a Class A, Class B or Class C fire rating.
4. If any portion of the waterproofing membrane is to remain exposed, the waterproofing system shall be
ultra-violet resistant.
5. Flashings must be installed in accordance with the waterproofing manufacturer's published specifications.
6. The waterproofing system shall be flood tested in accordance with ASTM D 5957.
7. The flood test shall take place after installation of the waterproofing membrane and prior to the
installation of any above membrane components, wearing surface or overburden.
8. An approved testing lab shall provide written verification to the building official confirming that
the flood test was performed along with the results, prior to final inspection.
Ron - I completely agree. I'm showing 1/4"/ft slope on my drawings and as you mentioned previously, I'm assuming no responsibility as it is out of my scope. I'm clearly stating that my drawings do not consider waterproofing or fire rating or anything relating to other disciplines. I'm clearly stating that my drawings only cover structural items. Honestly, I don't care if the occupied space below gets wet. It is not my responsibility to waterproof the deck and I'm clearly making the owner and contractor aware.
On sort of a side note, Sponcyv, I would also consider using this project as an opportunity to start learning how to specify drainage and waterproofing systems - specifically for parking and plaza structures. Competent structural engineers are perfectly capable of performing that task for common construction, and for small projects (such as the one you describe) it is a cost-saver for the client.
Speaking of client complications, I am assuming that the contractor/owner has shot down a formed concrete slab for this mezzanine, sponcyv? If not I would say that you recommend that over stay-in-place centering, because of being exterior. They may rather form it up than order G120 deck, which is not in stock. On the plus side, in order for a membrane manufacturer to release their warranty, they need to approve the substrate. The manufacturer can run some vapor transport calculations and specify the percentage of venting required for a non-vapor permeable soffit. Always lean on the material manufacturer's for their vast specialized experience.
My thoughts on the other items - No control joints - just be generous with your crack control steel and provide good details. Provide standard detail for construction joint in case their pour is interrupted for some unforeseen reason. Yup - no need for composite beam there. Non-composite beams are designed with the slab cast against the side of the compression flange all the time without studs, to prevent positive moment LTB. When the spans get long, you need to consider a cross-bracing for fascia beams to the interior beams for wind and generally stability. Obviously, when diaphragm transfer is an issue for a larger structure, some sort of mechanical connection is required. See the attached - it is a repair detail but you will get the idea. I show the repaired slab cast against the existing beam top cover plate (don't ask why that cover plate was there). Remember, if you take your moment diagram, scale it down by 98%, and then divide by the lever arm between the flanges, you have the required top flange brace force per foot. The value is always surprisingly smaller than you think you need.
Just following up on this.
I also agree.
What are you guys agreeing with anyhow? I just posted ajk1's references without even adding any sparkling commentary.
