Journal that open assembly and measure time needed to open it?
I am working with some big assemblies, and sometimes I would like to know how much time it take to open some of them.
Is it possible to make journal that will use open dialog to open assembly and measure time from clicking OK button till assembly is fully opened? Maybe show it as txt document when it is done...
RE: Journal that open assembly and measure time needed to open it?
The NX log file will show you how long it took to load and display a file. Open your file then go to the NX log file (menu -> help -> nx log file), scroll to the bottom and you will see some statistics on the file load.
www.nxjournaling.com
Nice. Better then journal as I can see it every time without special commands.
Thank you cowski.
Hi ,
You can also set an ENV variable ( user ) TIME_USER_EVENTS=true. This will give you more information in the log file..
Thanks, I will try it.
