Actual radial distance between hubs & Bolts
Dear All,
Will you please clarify about utube gasketed heat exchanger coming to the minimum radial distance between hub and bolts value is taken from Tema ( 9-21) for example the value is 20.637 for nominal diameter of bolt size 12.7 mm ( 0.5”).Then how to calculate Actual Radial distance between hubs and bolts.
Bolting Information for TEMA Imperial Thread Series (Non Mandatory):
Minimum Actual Maximum
Bolt Area, mm^2 1019.242 4552.249
Radial distance bet. hub and bolts 20.637 35.719
Radial distance bet. bolts and the edge 15.875 15.875
Circumferential spacing between bolts 31.750 31.777 86.785
Please do needful,
Thanks & Regards,
Satya.
RE: Actual radial distance between hubs & Bolts
satyamech9, look at the picture. Radial distance = 1/2 ( bolt circle - hub OD ).
Mike
Dear SnTMan
Thanks alot for your reply.
Satya
