Combine known column and row based on cell contents VBA
Hi All.
This seems like it should be easy and I know I've done something similar in the past.
Sub ScrollToName()
Dim RN As Integer
RN = Range("P5").Value
ActiveWindow.ScrollRow = RN
Range("E + RN").Select
End Sub
It scrolls to the top perfectly but I can't seem to get it to select the cell I want it to.
Obviously I'm missing something.
Thanks, Doug
Sub ScrollToName()
Dim RN As Integer
End Sub
Thanks, Doug
RE: Combine known column and row based on cell contents VBA
Range("E" & RN).Select
Works perfect.
CODE
Skip,
Just traded in my OLD subtlety...
for a NUance!
