Rebar Lapping
Rebar Lapping
I have two questions about lapping:
1. If lapping rebar to transfer tension force is a non-contact type, why the code does not require longer lap length than the same using contact lapping method? I am thinking that when a rebar is pulling out, ribs of rebar actually is compressing the concrete and spread the compression force at certain angle like 45' to transfer force to another one. In this way, the design lap length should be lesser than actual one, based on the assumption that concrete only transfer compression force, but not tension force.
2. If one T40 rebar is lapped with two T32 rebar to transfer tension force, will there be any deductions for such lapping considering the load transfer efficiency?
Any BS reference for the above questions? Thank you.
RE: Rebar Lapping
2) Not that I'm aware of. Lap length would be based on the tension to be transferred and the bond of the smaller bar.
