Load case vs combination?
What is the difference between load cases and combinations? When doing calcs by hand I only use load combinations (1.2DL + 1.6LL, etc.) At my firm when using software we enter both but the load cases are the load combinations multiplied by 1.
RE: Load case vs combination?
So, for example you might have the following load combination for multiple live load cases:
1.2DL + 1.6LL(case 1)
1.2DL + 1.6LL(case 2)
1.2DL + 1.6LL(case 3)
etc.
Professional and Structural Engineer (ME, NH, MA)
American Concrete Industries
www.americanconcrete.com
Load combinations are how the load cases are combined.
What load cases are defined?
What load combinations defined?
If you're inputting load combinations with a 1.0 load factor(1.0*Dead +1.0*Live), it may be for bearing pressures under foundations. Essentially inputting both ASD load combinations and LRFD load combinations.
I believe this doesn't make a huge difference until you get into non linear effects. For small, squat, simple buildings with low lateral forces, it may just be terminology.
