problem importing points from Excel
Hi everyone
I tried to draw a spline using GSD_PointSplineLoftFromExcel excel file, but when I run the macro, it shows an error message:
"license information for this component. You do not have an appropriate license to use this functionality in the design environment".
Can anyone help?
Thank You :)
RE: problem importing points from Excel
Hi Fredo,
I have GSD license and it is active
I dont know if DS update its code sample from online doc but just for us to better help you.. What is your version of CATIA and version of the catvba file ?
Eric N.
I know it has to work, but I couldn't find what to fix exactly
do you have catia running before you start the script in excel?
How do you start catia usually ?
Eric N.
I run Catia then I open the excel file
ok my feeling is that your excel script is link with a previous catia level, and when the script try to get catia it won't find the open one and will try to start a new one and then you're missing license.
in the script ( go to EXCEL VBA with ALT + F11) find GetCATIA() the run it one line at a time : bring cursor inside and press F8
and check if windows find your running catia or if it's trying to create a new process...
Eric N.
run-time error '429'
ActiveX component can't create object
what line?
Eric N.
Problem is in the line 144:
If CATIA Is Nothing Then
Try to register Catia. This may help. Put On Error Resume Next before If CATIA Is Nothing Then
and see what's going on.
