Thermal expansion for buried Pressure vessel located in sand filled pit
Hello all,
I am working on a vessel which is to be installed in a concrete pit. The pit will be filled with sand after installation of vessel as per local regulation requirement to prevent leakage of the process gas to outside atmosphere.
Vessel operating temperature is 230-C and the material of construction is CS.
Design and fabrication code is ASME VIII Div. 1.
Since the concrete pit will be filled with sand after installation, my understanding is that there will be no room for expansion of the vessel during operation since the free expansion of vessel will be restrained by the sand and the concrete pit.
Could you kindly advise how can we design the vessel for restrained expansion so that there will be no overstress of the vessel due to restrained expansion during operation?
Any ideas are welcome......thanks for your help.
D2HANDLE
D2HANDLE
RE: Thermal expansion for buried Pressure vessel located in sand filled pit
Check out EEUMA 190.
Please explain how that works ... Where in the world will this vessel be located ?
After the process gas works it way through the sand, what advantage is gained ????
By placing a hot CS vessel in a sand filled pit you will only ensure accelerated failure .... from thermal constraint of the vessel and accelerated external corrosion.
What MBA/local regulator came up with that idea ?
MJCronin
Sr. Process Engineer
What the bloody hell do they think they are trying to do? (Other than destroy the tank integrity.)
-320 degrees?
I am also not sure how and why sand filling shall be able to contain the release of harmful gases from the pit, should this happen.But there shall be a concrete slab at the top of pit and this may help for leakage issue in some way.
Well…the vessel shall be installed in one of the former soviet bloc coutries.And we are not familiar with all of the local regulations.. so we have to believe what our local consultant advises us, and they told us that as per the regulation, the Pit must be filled with sand.
But looking at the issue, we are tying to reverify with another local consulatant about the requirement for sand filled pit for this Vessel.
To tackle thee external corrosion, special paint devised for buried vessels, is planned to be applied.
I shasll keep the forum members updated with further developments.
D2HANDLE
Getting ventilation to get the air exchanged down there? it combines the worst of "not a tunnel" with the access to the bottom of "a deep vertical pit" with the hassle of "excavation".
Therefore, the very large vessel WILL "float up" in its surrounding sand bed as the container shrinks and swells with thermal expansion, as the sand settles and adjusts over time and with varying water percentages in the sand around the container, and with the varying internal weights of the container.
Over time, the sand around the tank will tend to loosen (up high around the tank) and then drop and settle further down (below the tank) thus creating a lifting force much like bouyancy in a liquid quicksand. Not anywhere near that quick, but the lifting force will need to be addressed somehow.
Before proceeding with this project, find out if other such installations within this country are in existence and if there were any problems associated with thermal expansion.
Mike
There are thousands of buried fuel tanks around the world. How do they do that without breaking things?
D2HANDLE - the previous underground vessels (mounded, actually) that I have designed that had thermal expansion had a non-collapsible foam applied on the vessel surface. More foam was provided at the ends, and special sleeves were provided for nozzle protrusions. Nozzles and other openings (think manways) will get bent rather quickly without special consideration.
