caustic soda dilution
Dears
please why always we should add caustic soda solution be diluted to water not vice versa?
Thank you
Thank you
RE: caustic soda dilution
If water is added to Caustic, a layer of hot weak caustic solution is formed at the surface, which boils and sprays around due to hydration energy of OH- ions. When Caustic is poured into water, it flows down and mixes much better, so no boiling/splashing occurs.
Dejan IVANOVIC
Process Engineer, MSChE
As a chem eng/metallurgist the first part of any answer I give starts with "It Depends"
http://dowac.custhelp.com/app/answers/detail/a_id/...
