Does concrete corrode aluminum ?
Hello dear engtip members. This is my first post into this discussion board.
I am currently working in a aluminum extrusion company.
Last week my manager, proposed a project that is construction of sun-shields for our parking lot of the factory.
The construction will be made out of aluminum.
I am thinking the use aluminum profiles to construct that.
First I will dig the ground and then land the aluminum profile in some depth with concrete.
But I wonder If is there any chemical attack would occur from concrete to aluminum?
Or
What happens if I use steel rods for reinforcement of profiles ?
Or
RE: Does concrete corrode aluminum ?
Dik
http://www.theconcreteproducer.com/concrete/how-do...
At my situation, aluminum bars will be in touch with fresh concrete till the concrete becomes dry. Well, after the concrete becomes dry the aluminum bar would be embedded into it of course. I wonder, in this case, long term contact with concrete would cause any adverse effect on aluminum ?
If you go with steel for this you also need to be careful. The steel in the concrete will be fine, but where the steel and Al meet there is also a chance for corrosion. Normally there are isolation kits used (washers and bushings) to prevent the two metals from touching.
