Adding User_Input during Journal Recording (Using C# Code)
Hello everyone,
I have used macro to perform a complete set of operation with "user input with instructions" option available in Macro. But in Journal recording (using C# code) how can I add user entry with instructions?
2nd question- what is the best way to do this- To define size of the text of the note I want to insert (using Journal) according to size of the sheet used.. i.e. if B -size sheet then 0.1 , if A size sheet then 0.05
. I was thinking about using For loop ... if so.. what is the right code in C#.
Thanks in advance for any help.
RE: Adding User_Input during Journal Recording (Using C# Code)
For your second question, it sounds like you want to vary the text height depending on the size of the current drawing sheet. If this is the case, no loop would be necessary; you would just query the sheet size and vary the text height based on the result.
www.nxjournaling.com
