Problem changing fonts in UG - solved
I tried to respond to someone else who had a mysterious problem like the one I just dealt with., but the thread was closed. So I figure I'll share this way.
I had a new drawing layout & for some reason I was not being allowed to change a font to mdcsolid. I've had this happen now & then before, but it seemed a bit random. This time, I decided to try to fix it. What worked was going to Utilities, Part cleanup, & deleting all unused fonts. After that I was able to change fonts as usual.
Hope this helps anyone who's been frustrated by this glitch.
RE: Problem changing fonts in UG - solved
BTW, unless you're running a very old version of NX, you really should be using the more modern TrueType fonts, particularly if you're looking for so-called 'solid' or filled fonts. The old UG fonts were not very good at providing a filled look while that's one the pro's for using TrueType fonts.
John R. Baker, P.E.
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Irvine, CA
Siemens PLM:
UG/NX Museum:
