How to load a model in the context of the root assembly in Teamcenter?
I need a way to load a model into NX in the context of the root assembly from Teamcenter using NXOpen. I am not sure how to do this. Typically one would do this from Structure Manager, where you can search for a model in the context of the root assembly, and it will find and launch the assembly into NX with the model loaded for you. I tried doing this with a journal recording in progress but it didn't really yield any helpful results. This is all it produced.
CODE
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim part1 As NXOpen.Part
part1 = theSession.Parts.Display
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Dim envValue1 As String
envValue1 = theSession.GetEnvironmentVariableValue("PRECISION_VALUE")
workPart.Preferences.UserInterface.DialogBoxDecimalPlaces = 3
Dim theUI As NXOpen.UI = NXOpen.UI.GetUI()
theUI.UserInterfacePreferences.DialogBarDecimalPlaces = 3
theUI.UserInterfacePreferences.ListingDecimalPlaces = 3
theSession.LogFile.WriteLine("Successfully updated precision values to default...")
Dim part2 As NXOpen.Part
part2 = theSession.Parts.Display
Dim fullPath1 As String
fullPath1 = workPart.FullPath
Dim historyList1() As NXOpen.BasePart.HistoryEventInformation
historyList1 = workPart.GetHistoryInformation()
Dim part3 As NXOpen.Part
part3 = theSession.Parts.Display
Dim fullPath2 As String
fullPath2 = workPart.FullPath
Dim historyList2() As NXOpen.BasePart.HistoryEventInformation
historyList2 = workPart.GetHistoryInformation()
Dim part4 As NXOpen.Part
part4 = theSession.Parts.Display
Dim fullPath3 As String
fullPath3 = workPart.FullPath
Dim historyList3() As NXOpen.BasePart.HistoryEventInformation
historyList3 = workPart.GetHistoryInformation()
Dim part5 As NXOpen.Part
part5 = theSession.Parts.Display
Dim fullPath4 As String
fullPath4 = workPart.FullPath
Dim historyList4() As NXOpen.BasePart.HistoryEventInformation
historyList4 = workPart.GetHistoryInformation()
Dim part6 As NXOpen.Part
part6 = theSession.Parts.Display
Dim fullPath5 As String
fullPath5 = workPart.FullPath
Dim historyList5() As NXOpen.BasePart.HistoryEventInformation
historyList5 = workPart.GetHistoryInformation()
Dim part7 As NXOpen.Part
part7 = theSession.Parts.Display
Dim fullPath6 As String
fullPath6 = workPart.FullPath
Dim historyList6() As NXOpen.BasePart.HistoryEventInformation
historyList6 = workPart.GetHistoryInformation()
Dim markId1 As NXOpen.Session.UndoMarkId
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Enter Gateway")
Dim part8 As NXOpen.Part
part8 = theSession.Parts.Display
Dim fullPath7 As String
fullPath7 = workPart.FullPath
Dim historyList7() As NXOpen.BasePart.HistoryEventInformation
historyList7 = workPart.GetHistoryInformation()
Dim markId2 As NXOpen.Session.UndoMarkId
markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Enter Modeling")
theSession.CleanUpFacetedFacesAndEdges()
'   Menu: Tools->Journal->Stop Recording
End Sub
End Module
Only this does not help me much. Does anybody know how to do this in NXOpen?
RE: How to load a model in the context of the root assembly in Teamcenter?
I don't understand the purpose, can you clarify ?
Tomas
