Automatic Datum Axis Creation
Dear All,
I need help for the journal or other type of NX custom for Automatic Datum Axis Creation,
In my case I have 8-points that connected with one to another with curves, it will looked like this picture, only one click will automatically created the datum axis. I have tried using macro approach, but fail. Somebody please give suggestions.
MAR.
MAR.
RE: Automatic Datum Axis Creation
CODE
Option Strict Off Imports System Imports System.Collections.Generic Imports NXOpen Imports NXOpen.UF Module Module1 Dim theSession As Session = Session.GetSession() Dim theUfSession As UFSession = UFSession.GetUFSession Sub Main() If IsNothing(theSession.Parts.BaseWork) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "NXJ journal" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) Dim myPt As Point = Nothing If SelectPoint("select a point", myPt) = Selection.Response.Cancel Then Return End If lw.WriteLine("point selected: " & myPt.Coordinates.ToString) Dim theLines As New List(Of LineRay) For Each tempLine As Line In workPart.Lines If PointsEqual(tempLine.StartPoint, myPt.Coordinates) Then theLines.Add(New LineRay(tempLine, False)) Continue For End If If PointsEqual(tempLine.EndPoint, myPt.Coordinates) Then theLines.Add(New LineRay(tempLine, True)) End If Next lw.WriteLine("number of lines from point: " & theLines.Count.ToString) For Each temp As LineRay In theLines Dim nullFeatures_Feature As Features.Feature = Nothing Dim datumAxisBuilder1 As Features.DatumAxisBuilder datumAxisBuilder1 = workPart.Features.CreateDatumAxisBuilder(nullFeatures_Feature) datumAxisBuilder1.CurveOrientation = Features.DatumAxisBuilder.CurveOrientations.Normal If temp.Reverse Then datumAxisBuilder1.IsAxisReversed = True End If datumAxisBuilder1.IsAssociative = True Dim added1 As Boolean added1 = datumAxisBuilder1.Objects.Add(temp.Line) datumAxisBuilder1.ArcLength.Update(GeometricUtilities.OnPathDimensionBuilder.UpdateReason.Path) Dim nXObject1 As NXObject nXObject1 = datumAxisBuilder1.Commit() datumAxisBuilder1.Destroy() Next lw.Close() End Sub Function SelectPoint(ByVal prompt As String, ByRef selPt As Point) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Select a point" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart Dim selectionMask_array(0) As Selection.MaskTriple Dim selObj As TaggedObject With selectionMask_array(0) .Type = UFConstants.UF_point_type .Subtype = UFConstants.UF_all_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selobj, cursor) If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then selPt = Utilities.NXObjectManager.Get(selObj.Tag) Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Function PointsEqual(ByVal pt1 As Point3d, ByVal pt2 As Point3d) As Boolean Dim modTol As Double theUfSession.Modl.AskDistanceTolerance(modTol) If Math.Abs(pt1.X - pt2.X) <= modTol AndAlso Math.Abs(pt1.Y - pt2.Y) <= modTol AndAlso Math.Abs(pt1.Z - pt2.Z) <= modTol Then Return True Else Return False End If End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End Module Class LineRay Private _line As Line Public ReadOnly Property Line() As Line Get Return _line End Get End Property Private _reverse As Boolean Public ReadOnly Property Reverse() As Boolean Get Return _reverse End Get End Property Sub New(ByVal theLine As Line, ByVal reverseIt As Boolean) _line = theLine _reverse = reverseIt End Sub End Classwww.nxjournaling.com
