compressors r404 and r134a
can a r404 compressor use r134a gas in running a high temp cooler. I have a r404 compressor and would like to swap out to a new r404 compressor. will the r404 compressor work with the r134a gas?
RE: compressors r404 and r134a
You need to consider the pressures the refrigerant operates under and possibly upgrade the components and possibly piping and also TXV....
