Butt Splice connection on 60 degree equal angles in self supported triangular lattice towers
Gentleman
We are designing a self supporting lattice triangular tower made up of 60 degree angles to support tale-communication antennas. However the 60 degree angle we are using is not hot rolled sections, But we are making 60 degree angle by bending the 90 degree angles to 60 degrees (please refer the attached drawing for clarity). Now we are making butt splice connection by providing 4 plates (two inside) two outside as shown in the attached drawing. Usually in a lap splice connection of angles we put I cover angle inside and two plates outside. However in our case because of space constrains we are unable to put a cover angle. instead we are using two cover plates. please advice is this connection is ok.
I seek your valuable advice in this regard.
Zafery
Zafery
RE: Butt Splice connection on 60 degree equal angles in self supported triangular lattice towers
How are they going to bend the angles? Per AISC, they don't recommend bending angles more than 5 degs for skewed connections stating that it is impractical. Not sure if the same ductility problems exist for angles as they do for plates bent parallel to their lengths.
