Need a script changes body size & constraint
Hi every one,
Can anyone help please,
I have a body (3 parts) and I want to write a script
which can change part sizes and constraint (angles between parts).
Thank u
RE: Need a script changes body size & constraint
what is the goal? to make changes in hundreds of files? day by day use? for a single part you can do it more quicker without scripting.
You have to understand when scripting is required and when not. The wing can be simply controlled by parameters.
Thank you JeniaL,
I know it's possible to change the parameters.
But, as I have to conduct tests on many configurations, I think that a macro where
you can change your parameters, will be much better than changing it (parameters) directly .
Ferdo is right. VB/forms is the way to go. Post at least part of a script.
Jenial had a good point and in your case I would go for design table for the following reasons:
That would be easy to setup (much easier than a script)
easy to switch from one config to another
easy to create new config
check online doc about design table
Eric N.
Thank you all, I will try it & feed back
