Adding on to / Thickening - Misaligned Concrete Foundation Wall
Is there a good way to increase the thickness of an existing concrete wall or help ensure the new concrete will not spall off?
In this case there is an existing foundation wall that was poured out of square and now the brick veneer will overhang the wall 1-5/8" to 3-1/2". The owner would like them to add on to the foundation wall by pouring new concrete.
I am worried that something like 1-5/8" would spall off and does not provide much cover if reinforcement was added. My thoughts are - Roughen the existing surface and install some headed studs that are epoxied into the existing wall and extend to within 1" of the new exterior face (in order to help grab hold of the new concrete).
Any suggestions?
Thanks!
EIT
www.HowToEngineer.com
RE: Adding on to / Thickening - Misaligned Concrete Foundation Wall
I've been looking for an opportunity to use these: Link. I'd check with the manufacturer regarding the suitability of the system for an extensive repair like this.
Is hydroblasting to get an exposed aggregate surface viable for your project? Otherwise pinning the layers using either powder actuated fasteners or KootK's screwed pins may be the best option. Probably size and space the pins to provide sufficient support assuming the entire section delaminates.
Sika makes products that work well for thin applications on vertical surfaces. I've used it before for large area repairs on a wall and it does appear to work fairly well.
Professional and Structural Engineer (ME, NH, MA)
American Concrete Industries
www.americanconcrete.com
Thanks for the replies, both appear to be good ideas.
EIT
WWF w/ your idea of studs to hold it in place sounds good
http://cavdiseno.com/inspirob/sites/default/files/...
It's used a lot for remediation in latin america, never seen anything detailed like this in the US though.
