real pump curve
real pump curve
Hello All
Let's suppose I've got in hands the pump theoretical curve (given by the Euler equation) and the efficiency pump curve. Can I estimate the real pump curve simply by multiplying the theoretical curve by the efficiency at any flow point?
Thank you in advance
RE: real pump curve
It is fine if you considering a design for a pump, but not for application.
RE: real pump curve
RE: real pump curve
