MV Voltage Regulator, 32x5/8%
Dear colleagues.
We are try first time connect voltage regulator in our application.
Actually, we have two options now: Cooper and Siemens single phase voltage regulator.
Our system is 22kV, compensated grounding. Three single phase VR will be connected in closed delta or ungrounded Wye type.
What will be influence on the ground fault protection?
Thanks in advance.
Thanks in advance.
